Dave and Paula,
I will agree that the lap used can be made of material at hand with good results IF a lapping compound is used that is correct for the job.
I re-read my post (glanced actually) to see if I posted erroneous information; but I don't think I did. Unclear information, probably! In the second paragraph, I mentioned different types of lapping compound, some won't break down easily and will embed into the work, diamond being nasty for this. A softer lap helps prevent grit remaining in your workpiece.
I base much of this on what I've learned on molds and dies over the years, not on small engine building. I can say from experience that I've too many times seen someone lap a hole in a mold with a hardened pin and diamond paste. No matter how well that hole was cleaned, it would leave black marks on the molded part. This was the lapping compound still doing it's job!
Brian,
No, not stupid at all, just one of those things that you pick up as you go. I'm sure somewhere along the line, books were written on the subject of lapping, and I may just have one somewhere; but it sounds like you were given "run in" instructions perhaps?
Just my $.02.
Kevin
Brian,
Just my $.02.
Kevin
