My hit n miss engine has developed an ignition fault. The spark is very weak almost to the point of being invisible, so preventing the engine from running.
The engine uses a standard Kettering type ignition with points and coil. The battery pack (9.6 volt rechargable) is fully charged. I have tried using a 12 volt battery with no difference in sparking ability. The points are clean. The plug is brand new, although it makes no difference whether I use the old or new plug.
So over to you panel of experts for a possible cure, please.
The Emerald Isle
The Emerald Isle
