How would i machine this?
student_Machinist said:
I see what you mean with the loading and it would be better if was oriented in a Y position with the two bearing on the top but i cant think of an easy way to do it, any ides?
turn it upside down?
True lol but theres not really a nice way of having a mounting bracket on the underside and it need the adjustable bearing on the bottom so i wouldn't be carrying so much load
You could try 2"x1" Bar
mill two passes flat (cut 1 and 2)
then clamp in V blocks and mill cut 3 and cut 4
tap and thread the block for top ball/roller bearings
mount adjustable bearing on the eccentric underneath
Bez
Bez
Lol thats almost exactly the design i was thinking of ;D What do think of this? btw it will have an adjustable cam on the bottom bearing i just havent drawn it yet
That design looks better, with a 12mm guide rail those top bearings will need to be staggered so the axles can have some depth in the upper surface of the carrier. (just a thought) Using my eyeball scale, those bearing would be 7-8mm D, with a 3mm axle. Is that enough for the load + forces you expect to see.
Yea thats not a bad idea, it wont be taking much load tho so it shouldn't mater too much. The dimensions i have been using are 5mmID x 10mmOD x 4mm bearings with a 0.5mm spacer, 12mm x 330mm shaft and total length of the slide is 100mm.
Do you have any idea where i could get shim washers to space the bearings off the block?
