How to remove the bezel of a Mitutoyo 505-626 dial caliper
Discussion in 'Tips and Tricks' started by moditwell, Apr 17, 2018.
Help Support HMEM by donating using the link above.
  1. Apr 17, 2018 #1
    moditwell
    moditwell
    moditwell
    Apr 1, 2018
    16
    3
    Has anyone had success in removing the bezel of this dial caliper? it cannot be pried off. The bezel cannot be unscrewed off. i tried to shim it from underneath but still no success. i have no idea how. Any suggestion?
  2. Apr 17, 2018 #2
    WOB
    WOB
    WOB
    Sep 12, 2013
    98
    25
    YouTube has several videos on dial caliper repair. [ame]https://www.youtube.com/watch?v=vYpe0uNpXyQ[/ame] is one but I don't believe that your bezel is held on by an O ring.
    This document shows exploded views of different vintages of your model: https://www.mitutoyo.co.jp/eng/support/service/parts_list/result.php?code=505-626&shorui=505-21 I can't be sure but it appears that the bezel is held on by a screw at the top of the dial ( part #'s 21 and 22 in the first document). Good luck.
    WOB
    Buchanan likes this.
  3. Apr 19, 2018 #3
    moditwell
    moditwell
    moditwell
    Apr 1, 2018
    16
    3
    There is no screw or any type of fasterner holding down the aluminium bezel. I also have exploded view of this caliper but it does not show the details of the bezel. Really no clues. 505-626 and 505-675 have different bezel mechanism
  4. Apr 19, 2018 #4
    Hopper
    Hopper
    Hopper
    Feb 19, 2013
    575
    186
    Have a look at the Long Island Indicator website, particularly this page here http://longislandindicator.com/p233.html on replacing indicator crystals. It goes through the many different ways bezels may be held on and removed etc. Might give you some ideas to try out.
    Otherwise, might be a case of "Insert credit card, buy new caliper".
    RM-MN likes this.
  5. Apr 19, 2018 #5
    RM-MN
    RM-MN
    RM-MN
    Feb 25, 2017
    55
    12
    But, but, new calipers are so expensive.
    https://www.ebay.com/itm/Mitutoyo-A...510270?hash=item3b09faedbe:g:iz4AAOSwdIBa1~DH
  6. Apr 20, 2018 #6
    moditwell
    moditwell
    moditwell
    Apr 1, 2018
    16
    3
    Thanks to everyone who share their many suggestions on how to remove the bezel. And here its is, out and the guts are visible.
  7. Apr 20, 2018 #7
    Hopper
    Hopper
    Hopper
    Feb 19, 2013
    575
    186
    So, how did you get the bezel off in the end? (Just in case I ever need to.)
  8. Apr 20, 2018 #8
    moditwell
    moditwell
    moditwell
    Apr 1, 2018
    16
    3
    Apply pressure from bottom of the bezel at 2 points 180 degrees apart. Press hard enough and the bezel is released.:D
  9. Apr 20, 2018 #9
    Hopper
    Hopper
    Hopper
    Feb 19, 2013
    575
    186
    A sort of refined version of brute force and ignorance then/ :D
  10. Apr 20, 2018 #10
    Buchanan
    Buchanan
    Buchanan
    Buchanan
    Nov 21, 2012
    184
    222
    Sorry for the wrong advice. I am glad you have it open now, next time it will be easy! What are you going to do with it now? Clean it, or is there something not working.
  11. Apr 22, 2018 #11
    moditwell
    moditwell
    moditwell
    Apr 1, 2018
    16
    3
    No worries. I had to replace the old yellow and broken crystal. I made a new crystal and pressed it into the bezel. Cleaned up a ton of gunk inside and lubricated the moving pinion. Now its silky smooth. incase anyone making a new crystal, the dimensions are 0.8mm-0.9mm
    thick acrylic sheet , diameter is 34.06mm. Bevel angle at the circumference is 20 degrees.
  12. Apr 23, 2018 #12
    Cogsy
    Cogsy
    Cogsy
    Moderator Moderator Global Moderator
    Jul 30, 2012
    2,226
    641
    Gender:
    Male
    Perth, Western Australia
    Wow that is a small pinion, especially if you know how small an Aussie 5c coin is!
  13. Apr 23, 2018 #13
    10K Pete
    10K Pete
    10K Pete
    Jan 25, 2009
    534
    120
    Well, ten revolutions per inch.... that's a tenth of an inch circumference at the pitch diameter.... yep, pretty darn small!
    Pete'
Share This Page
