I have been trying to understand the various types of "fit" referred to in plans and in the various build threads. I've searched around the net but not been able to find any definitions which indicate how close in size one part is to another when a particular type of "fit" is indicated.
For example, if a 0.375 inch shaft is to run in a bushing, what should the size of the hole be? Is this what is described as a "close fit"?
Similarly, what would the size of the hole be for a "press fit"?
I've also seen mentioned "interference fit" which I gather is constructed by heating one part and chilling the other to the point where a "press fit" can be made. I may be completely wrong here.
There is also the technique used where a bearing for example is inserted into a bored hole and loctite used to secure it. What are the relative sizes of the parts in a case like that?
I realize that in practice a machinist will from experience, depending upon the materials being used and possibly the phase of the moon, know how close to machine the parts and will then (guessing here) sneak up on the final fit.
What I'm looking for as a complete rookie is a target to shoot at when undertaking these various types of "fit".
Is there a book that covers this sort of thing?
