dwentz
- Dec 20, 2007
- 120
- 5
OK, I am in need of a little help.
I have this Chinese built lathe, its a CZ-300a, but is not like the current CZ-300a's found on the internet. It has a 2 1/4-8 thread on the spindle. The book states that it has a MT 4 1/2 short taper in the spindle. The problem is there is not a standard for a MT 4 1/2 that is a standard. I have found the specs on this taper, and they very from manufacture to manufacture. Some of them say the taper per foot is the same as a MT-6
So I set off to measure it. I put a lever type dial indicator on the cross slide with the ball pointer in the spindle and set it to zero. I moved the carriage 1 inch and got a reading of .029 inches. I was assuming that this would be the taper per inch, but it is not close to any of the standard Morse tapers that I found. Am I missing something?
The goal is to make an adapter for 5C collets and MT3 tooling so I can turn between centers.
Dale
Dale
