A couple more thoughts came to mind since my last post
If you are using the KmH scale on the bike computer, you could space 3 magnets equally around your wheel, and be able to program a a slightly smaller wheel circumference into the bike computer such that 25KmH = 25RPM. If you want to use he MPH scale, you would need to space 5 magnets equally around the wheel at which point a slightly smaller wheel circumference would allow the bike computer where 25MPH = 25RPM. In fact, if you wanted the computer to be very responsive to any speed fluctuations of your wheel, you could equally space 6 or even 7 magnets around the wheel, and program progressively smaller wheel circumferences such that 25MPH = 25RPM. This is just a simple game of math and ratios, for which you now have enough formulas to play around with. Remember, the bike computer simply counts how many times a magnet passes by the pickup unit, and each times assumes the wheel has travelled the programmed circumference, from which it can then derive speed.
The second option is as simple as it gets and I am kicking myself for not having thought of it sooner. Many bike computers have a cadence option, which gives a second magnet and pickup unit to monitor pedal revolutions per minute. If you got a bike computer with a cadence option, you simply attach a magnet to your wheel, and the cadence setting will display the actual RPM. No fuss, no muss, done!
If want your bike computer to be more sensitive or responsive to fluctuations of RPM, or accurate to a tenth of an RPM, you will need to mount additional magnets to your wheel, and divide the RPM display by the number of magnets, or change the wheel circumference setting if using MPH.
Robin
