Kaleb
Senior Member
- Jan 3, 2010
- 272
- 27
This is my first engine build, so nothing too complex or fancy, so here we go.
The cylinder starts out as a piece of copper tube, about 10mm ID.
First cut with the hacksaw.
Ending up with this
Facing in the lathe
A simple lapping tool made from a piece of dowel with some 600 grit Wet & Dry paper held on by Blu Tack.
Lapping in progress with the tool in the lathe
And finishing by hand
Filing a flat on the side of the cylinder to take the port face
Turning the piston from some aluminium rod
And center drilling to take an M3.5 tap.
The piston after cutting off and threading
The piston screwed on to it's conrod, with the cylinder on the left with an end cap sweated in, as well as a piece of brass for the port face.
More to come soon, I'll let you post your comments.
Ending up with this
Facing in the lathe
