Finish on pattern
Discussion in 'Home Foundry & Casting Projects' started by stevehuckss396, Nov 24, 2013.
  1. Nov 24, 2013 #1
    stevehuckss396
    stevehuckss396
    stevehuckss396
    Model Engineer Project of the Month Winner HMEM Supporter
    Nov 19, 2008
    4,128
    1,021
    Gender:
    Male
    Occupation:
    Construction
    Sterling Heights, MI
    What kind of finish is best on patterns for casting. I have tried to do a very smooth clear coat but the sand seems to want to stick to it. I try to dust the pattern but the powder won't stick to the pattern either. Would a gray primer work better with a little bit of a rough finish so the parting dust will stick to it.
  2. Nov 24, 2013 #2
    enfieldbullet
    enfieldbullet
    enfieldbullet
    May 2, 2013
    145
    20
    i am still to make my first pattern but i gave that issue some thought already.
    i was considering using two part epoxy paint as it is fairly hard and doesn't dry tacky as enamel and other stuff does.
    in my books varnish is quoted several times, that and lacquer. it'll probably take a few test pieces to figure what works best.
    spray paint seems like a good cheap alternative also. the key i think is a thin layer so it won't get charged with the sand.
  3. Jan 6, 2014 #3
    Tharper
    Tharper
    Tharper
    New Member
    Jan 6, 2014
    1
    3
    I use Rustoleum automotive enamel. I seal the pattern with shellac then spray on a coat of automotive primer. Sand, fill, sand some more than prime and finish paint.
    I have also used varnish with good results.
    [​IMG]
    [​IMG]
    mnay, NitroExpress and TimTaylor like this.
Share This Page
