I'm doing the cross slide upgrade on my 9 x 20 Lathe from the stock 6mm to 7/16" x 20TPI. I got a 7/16" x 20 TPI LH Die and the screw has a taper in it? The starting end is the right size but it tapers to the point that the new 'nut' seizes up about 3/4 of the way down the screw. (BTW The diameter of the rod was turned consitent)
The die is adjustable and I re-chased the threads about 5 times and the screw now appears fine, but, having only tapped\died(Sp?) 1~2 inch screws\holes up to now, I've never encountered this phenomenon.
So what should a person be looking out for whilst doing longer screw threads?
Thanks,
Chazz
Thanks,
Chazz
