Has anyone had any luck with a stepped D bit reamer? I make a turned aluminum part with a flat bottom hole. The hole is fairly deep so a boring bar is tricky. 5/16" diameter and up to 1.5" deep. For the sake of simplicity, I had been using a 5/16" endmill. Sometimes it worked nicely and other times chatter made for a poor finish on this bore I'm trying to seal with an O-ring. There is a slightly larger diameter (T letter drill) counter bore on this hole that equals half the depth. I was thinking that I could make a D bit reamer with both features and sink it into a drilled 1/4" hole to remove much of the material.
I was messing around with a D bit reamer made from a 1/4" HSS drill blank and was pretty surprised by the cutting ability and smoothness of the resulting bore. I've never tried them before. It's not exactly a high speed procedure, but I'm sure the way I make it now is slow.
I also hadn't had much of a need to turn drill rod before, but since I was experimenting I gave it a go. C6 brazed carbide tools did a wonderful job, I was quite surprised.
