Hi! I'm new on this forum. I'm pretty ignorant about all things related to machining. However, I retired a few years ago and, over time, have equipped my workshop with a number of toys. Some have been good/great decisions. Some have not. The jury is still out on my AL320G metal lathe. When I bought it, it was quickly apparent that it had been shipped with no lubrication whatsoever other than the oil in the headstock. I see that others have had similar problems.
I've been using it for about a year on this and that but I have studiously avoided thread cutting as it seemed a very daunting task. I have this set of spare gears and a gear/thread cutting chart that were a mystery to me and I always found a way to not need to cut threads.
Well, I decided that being scared is a very non productive thing to be. I worked through the chart and the gears and found a project that entailed cutting an M30 x 3.5 thread. I set up the gears, worked out the use of the half nut and started with a very light cut. I did not disengage the half nut at the end of the first run. I put the lead screw in to neutral, backed off the cutter, reversed the lead screw back past the start of the cut, brought the cutter back in and resumed the cut. The second run was very slightly out but the third cut was halfway past the first cut.
Research on the net showed that lead screw end play and/or half nut free play would be the likely culprits.
The half nut was tight as a drum. The lead screw, however had lots (and lots) of end play. I know this is not a top of the line lathe but it's still expensive enough that it shouldn't have that much play. There doesn't seem to be any capacity for adjustment so I have made an adjuster as per attached pic.
Having adjusted the end play, I was frustrated to find nothing had changed: the first run was out a few thou, the second run was way out.
Help!!! Anyone? I feel like I've been sold a lathe that can't do what it was advertised as being able to do.
