cross joining tube
R.G.Y.
r.g.y.
I need to cut a scallop out the top of a 28mm tube so another tube of the same diameter will fit down 6mm across at 90degrees. I only have a lathe with a vertical slide. Or is it down to hand work. I hope not as i need 20.
Sounds like a job for some sort of jig and a boring bar
How about a 28 mm end mill in the chuck and the tube mounted on the vertical slide?
Thank you both just the inspiration I needed. R.G.Y.
