Hi,
I am building a new engine from my own design and i am confused what type of bearings i should use on the crankshaft. In the front of the engine i am going to use two ball bearing with one of them just 1mm apart from one of the crank throws and the other ball bearing will be in front of it. Because the crank has two throws i will also support the other end on some type of bearing. The bearing in the end will be located (housed) in the crankcase backplate (cover). I was going to use a needle roller bearing to be able to remove the backeplate easily because as you know a ball bearing would be almost a press fit on the shaft therefore i wouldn't be able to remove the backplate easily once i would assemble the backplate. Thus a needle roller bearing would be ideal to use because of it clearance between the crankshaft. The question is will ill be doing something wrong if one one end of the crankshaft i will use ball bearings and on the other end i will use a needle roller bearing?? ???
Thanks
Thanks
