chillybilly
- Nov 29, 2008
- 217
- 0
Not strictly engine related ,move if required
A lull in production of the hasbrouck #10 "change is as good as a rest "
My Mum is a lover of nuts Cracking the shell in the regular screw or scissor action method is now no good as the rhumertoid arthritis in her hands makes it impossible .
At this festive time it was mentioned so i decided to engineer a solution so............
Went in the swag box and found 2 ends of a scrap valve ,faced those up and took away all the lugs etc that made up the valve ,trued up the bores .
Next turned up the brass bushings to fit into the end plated .
Made the stainless steel columns from old handrail with M10 studs (waste bits from work .) that connet the bottom threaded brass bush with the plain brass bush in the upper plate ,with nuts to tension it all up .
Ends were made for the columns ,brazed in then machined flat ,spun round and faced to length .Plug was made for upper plate shrunk fitted in and bored through 14mm ,lower plate had the anvil made at 30 deg inclussive with a 10mm hole in the bottom (hazlenuts).
Next the globe ,the internal contents of a scrap valve i cut up years ago its has been sat on my shelf for ages coz i thought it pretty
Dilled and tapped that M10 then got a length of 14mm silver steel threaded m10 both ends screwed one into the globe and one whizzed up a bit of stainless for a handle .Put it all together and it really works a treat .Quick coat of paint on the ferrous bits .
Does all the nuts i tried no worries and does not bust em to bits .
My mum is chuffed to bits and has certainly got the knack ,so i should be in for extra portions on the 25th :big:
