Runner
- Feb 10, 2011
- 124
- 17
Hi all,
I am just about to start machining the driver and driven wheels for a 3.5" gauge steam locomotive. They are 4.5" in dia machined. Unlike wheels I have machined before, these come with a boss at the centre of the reverse side. I don't know if this boss is an aid to machining or just an artefact from the casting process. I assumed at first that it is an aid to machining and tried to use the boss to mount the wheel in a 4 jaw chuck. I was able to adjust the positioning so that the wheel was reasonably concentric to the lathe axis, but there was a significant wobble and the wheel could not be made to run square to the lathe axis. This is because the chuck jaws are stepped and the centre of the chuck the area of the jaws in contact with the wheel's back face is small. Should I cut off the boss and machine the wheels using a backplate slightly smaller than the wheel dia? If anyone has experience in machining wheels with the boss I would like to know the steps involved.
Thanks in advance
Brian
Thanks in advance
Brian
