Gordon
- Jan 4, 2011
- 1,333
- 344
Well so far the new year is not going any better than the last year. Worked all day yesterday and I still have the same problem as last year.
I am building the Upshur Twin Horizontal and it does not even try to run. The problem as usual is compression. I have made new pistons and tried new rings. If I put compressed air in the cylinder I am not finding any leaks and there does not seem to be air leaks around the piston. The strange thing is that I seem to have good suction on the intake stroke and almost nothing on the compression stroke. If I put my finger over the spark plug hole it holds suction but almost nothing on the compression stroke. Very minimal air leakage around the valve when using compressed air. That is backwards because under compression the valves should be forced harder against the seat and under intake they should should be pulled away from the seat. Obviously I am missing something. Maybe it is time to do something else for a while. Probably not the Atkinson Differential because that is also just a source of frustration.
