Phil Duclos' "Fire Eater" engine in the Steam and Stirling Engines You Can Build (book 2) has a doorknob-based lamp. No doubt those plans were also published elsewhere, but the word 'plans' is a bit of a stretch for the few sentences on making the burner-- it's pretty easy, as above.cobra428 said:Dan,
Somewhere I saw a lamp made out of cheap brass plated door knob. Took the guts from the knob leaving an empty shell. Brass tubing to your liking. Drill a hole near the top to fit tubing at an angle. Glue tube to knob from the inside (JB??). Turn a lid to fit.
It looked good. Oh you'll need to flatten the bottom (side firdist from the door).
I look thru my stuff tonight to see if I can find it
Tony
I think it my be on this site do a search
