Miniature beam engine.
Johan Maritz
Active Member
South Africa
Hi guys and girls, i recently saw a tiny little beam engine on youtube. It is made by Microcosm. My question is, does anyone have a drawing of this engine, it looks fairly simple, except the valving, I'm not exactly sure how that is done. Would any one have a drawing, even a rough sketch of this little engine. Would appreciate any help.
Regards Johan
Dear Johan
I am sorry but I was wrong. It is a steam engine and the valving is shown on the picture on the lower right hand corner.
I apologize.
If you wish I can make a drawing of this little machine, however it will be up scaled by 2.
Kind regards
Julius
Hi Julius, it would be greatly appreciated if you could do a drawing on this engine. Scaled up by 2 is perfect, these things do get fiddly when so small.
Kind regards
Johan
Dear Johan
I apologize.
Kind regards
Julius
[/QUOTE
Good Day Sir
I too would be interested in drawings when available of the steam engine (photo attached)
Email [email protected]
Thank you
Robert Wager
Dear Johan
Did you receive my drawings via e-mail?
I have attached the drawings here.
Kind regards
  • 09E-57-00-A3-SHEET-01 -.pdf
  • 09E-57-00-A3-SHEET-02 -.pdf
  • 09E-57-00-2-205-MOVING PARTS ASSEMBLY.mp4
    4.1 MB
  • 09E-57-00-2-205-MOVING PARTS ASSEMBLY-1.mp4
    4.1 MB
  • 09E-57-00-2-205-MOVING PARTS ASSEMBLY-2.mp4
    8.2 MB
Only found this site yesterday and accidentally ran across this post.
I purchased the miniature Microcosm Beam Engine some time ago because I could not find a suitable beam engine plan and really wanted a beam engine in my collection.
A few days ago I completed a copy and scaled it up 3x. My old hands have trouble with tiny bits these days :)
I did not draw plans but scaled straight from the original Microcosm Engine.
Made some modifications as I did not have big enough pieces of brass so used aluminum and split the main body in two pieces.
The Microcosm engine did not work (linkages too flipperdy flopperdy) so concentrated on well fitting links and I split one link and made it adjustable with some threaded rod.
As you can see from the attached files it runs beautifully and started with the first flip of the flywheel much to my delight.
Mike
P.S. Julius does a fantastic job of drawing these little engines and have used his plans on other projects
  • VID_20211006_151434(0)(0)(1).mp4
    12.2 MB
Thanks for sharing Mike, exactly my idea as well to possibly make the cylinder part on it's own and the somehow bolt it to the mainframe.
