Wyvern Engine Carb.
DLM
I have about finish my Wyvern but can,t seem to get it to run very well that carb. i think is not the best desine
is there a better one to use. I was thinking about making on of G. Britnel little carbs. i have a set of his prints
Does anyone have any better ideas? Thanks Don
Thanks for your input. Do you have a print with more specs on the internal parts?
I guess i can come up with my own . Thanks Don
yes
  • ASSY-JAG NEEDLE VALVE.PDF
  • JAG CARB BODY.PDF
  • JAG END-CAP-1.PDF
  • JAG END-CAP-2.PDF
  • JAG FUEL PIPE.PDF
  • JAG NEEDLE VALVE-ORIGINAL DESIGN.PDF
  • JAG SPRAY BAR-ORIGINAL DESIGN.PDF
  • JAG THROTTLE BARREL.PDF
  • JAG THROTTLE LEVER.PDF
  • SOLDERED SPRAY BAR ASSEMBLY.PDF
The Jerry Howell design is a good one, though more challenging to make than the JAG. The Howell plans are not free, either. I expect the size of the Howell would work well with a Wyvern. I had to scale the Howell design by 0.75 to make it work with my Upshur Twins.
