G'day Macca
to get back on thread i spoke with Adolph ( his real name) from hare and forbes
he suggested 50 kilos depending on how you mount it 75 is pushing it as the bed will get dinged with the slightest knock at that weight he said.
he has grinders that mount and they weigh a bit over that and are a bit wobbly if not mounted well so he went under to be safe
if in doubt ask for the kraut at H&F what he dont know is hard to get info
I had to call him about some bits ( indexable ) for a weird arse cutter i have , negative rake.
they did not have them but he knew where to get em... not there either, hes a straight up bloke
pity the rest of the place are pretty slimy ( nth parramatta store i dunno about the rest)
talk to Adolph but he is retiring soon and i also invited him here, apparently he makes his own glow plug engines for his R/C planes!! scratch builds!!
hth
cheers
jack
sorry started writing this a hour or so ago and missed the other posts ( got distracted by a car fire here, bloody wogs)
heres what i did with mine,
i do not use the drill press much now ( have the grizzly mill )
so if you would like to borrow it and the small mount i made for it let me know i have used the slide section for another job since but the small foot is only 10 cm in dia. so should mount well to the cross slide.
cheers again
