chucketn
Senior Citizen
I have just finished and assembled my second engine, a Poppin Flame Licker engine. It's rough as a cob, but I hope to get it running. Once it runs, I'll add the bling. This has been a very good learning project. I found ways to get so much more out of my available tools.
I varied somewhat from plan, adapting to materials on hand. I made the valve gear like Byrne(wizardofwood) did.
My problem is the valve, made from .002" feeler gage, only uncovers about half of the intake port. I think I need to trim the low side of the cam to get the valve rod to pull the valve down more. The cam moves a hard drive bearing screwed to the end of the valve rod as a cam roller. The cam on the "Poppin" plan is basically .5" rad for 110° on the high or valve shut side, and falls back to .300" on the open or low side. I measured with calipers that the cam needs to be .546" rad on the high side and .262" on the low side. Is this kind of fudging common in engine building?
Chuck in E. TN
Chuck in E. TN
