Using an end mill as a form tool on the lathe
BobWarfield
I thought this was a wonderful idea when I saw it:
Seems brilliant not to have to deal with hardening a piece of tool steel or laboriously grinding out an arc when there's a tool at hand that will already do the job.
You'll need a QCTP or other holder capable of holding your corner rounding cutter (or other shapes you may have), but this seems like it works well. I wish I could take credit, but it came from a fellow I've learned a huge amount from called "Widgitmaster". He posts over on CNCZone. He makes CNC routers for others, but his own work is done (so far) on a manual lathe and mill. Here is the thread that photo came from:
http://www.cnczone.com/forums/showthread.php?p=458319
It's a long thread, but he is building up a beautiful large CNC router. Lots to learn from the various machining ops he performs. He's done a number of other interesting things including adapting a surplus Hardinge turret to his import lathe to speed up various ops. All of it is detailed in various threads over there.
BW
Good tip Bob.
I was only thinking the other day that I needed to grind up some concave tools. There is now one job less that I need to do.
In fact it might also work with some router bits that I have been trialing on the miller. Must try it.
Thanks
just remember your clearance angles with that id stuff
