Cedge
- Jul 12, 2007
- 1,730
- 29
I managed to score a small chinese made 4 inch rotary table from the old fellow I recently bought tools from. Like most chinese iron, it needed a bit of tweaking before it was ready to go to work. There seemed to be quite a bit of lash in the system, so after cleaning the red grease off the little fellow, I proceeded to attempt making adjustments.
The thing needed a bit of attention. The key way had some slop in it, but a few stout taps of the hammer on the square key had it fitting nice and snug. Then I had to loosen the two retainer nuts behind the dial and tease them into a position where the end play in the shaft disappeared. So far so good.
The shaft assembly is housed in an eccentric which allows the worm gear to be adjusted to the pinion gear. this assembly is locked by two setscrews. If the eccentric is moved too far, the work will disengage from the pinion. Moving it the other way engages the two gears. I've got them meshed as well as itappears they can be mated, but I'm still seeing a bit of travel in the dial before the table moves.
I have a pretty sure feeling that the remaining lash is due to loose tolerances between the gears. I have not torn the table all the way down, yet but I'm wondering if anyone has any suggestions on how I can chase that last bit of slop out of the gears.
The factory "zero" mark is one of those riveted tags and it appears that the operator missed his mark by about 3.5 degrees, but That one is easy to solve. I'll make up a new zero mark and correct that with no problems. I know... its not a high dollar tool, but its mine.... for $25.00 ...LOL
I'm excited about the new toy and want to get it working at its best potential. It might not replace the fun of using my homemade indexer, but it will surely add a new level off accuracy, with or without a bit of annoying lash.
Steve
Steve
