Majorstrain
- Dec 24, 2008
- 304
- 4
It's been a while since I've posted a project, but I have had a few on the go.
This is one of them.
A tooling plate
It's 24" x 10" and has a threaded hole grid of M6 x 1 at 1" spacing. In between those it has reamed 6mm holes at a 2" spacing for fixture alignment using 6mm dowel pins.
It's made out of some 20mm mild steel plate that was sitting outside at work and weights in at 22 kg's
It has mounting holes that suit my Bridgeport T-slots and my soon to be completed CNC X3 (the other long running project)
I spot drilled all the holes, then drilled and machine tapped the threaded holes.
Those with a keen eye will notice two holes missing in the pattern. That's where I broke two M6 spiral flute taps running them in and out at 400rpm.
They both broke on the start of the return journey out of the hole at around the 70 holes each.
To remove the taps I just core drilled the broken taps out with a 20mm rotor broach bit which drills out an 11mm core and then turned some 20mm plugs up on the lathe and Loctited the in.
I then took the plate into work and surface ground the top and bottom.
By then the 6mm carbide reamers had arrived and I reamed the alignment grid holes.
From memory there are something like 207 tapped holes and just over 100 reamed holes.
Now I need to make some low profile eccentric clamps like Shred.
http://www.homemodelenginemachinist.com/index.php?topic=2498.0
And finish the X3 conversion.
Phil
A tooling plate
Phil
