lazylathe
- Aug 27, 2009
- 1,285
- 6
Hi All,
A few weeks ago i picked up an Atlas 618 lathe.
It was painted without any disassembly or cleanup, just a coat of silver paint to hide everything.
I stripped the whole lathe and cleaned everything.
Some parts were sandblasted to bare metal while other more sensitive parts were cleaned with paint stripper and a wire brush.
The ways had some serious damage to them and i was unsure if i could manage to fix it in a way that would still give me a functional lathe.
What i ended up doing was using a two part Cold Weld epoxy.
Mixed it up and filled the damaged areas and then clamped 90 degree angle iron on top to keep the surface smooth and to squeeze out any excess.
This actually worked like a charm!
A bit of light sanding with 1500 and 2000 water paper and a bit of oil and the ways are smooth again!
It still looks a bit rough but the cold weld is so thin it is transparent!
The cross slide works perfectly across the repaired areas and the rust monster has been put at bay!
Shot of lathe assembled after being restored
Headstock and name badge after restoration
Cross slide after restoration
Tail stock restored
I still need to make a platform for the lathe to sit on.
Will fashion it out of wood and have a steel top that the lathe will be bolted to.
The countershaft assembly is still drying, but it is the same colour!
I still need to strip and clean the motor. It is only a 1/4 hp motor but should do for now!
Someone decided to paint it black and again did not do a very good job!
So far i have cleaned one end cap and it is shiny silver aluminium under the paint.
I wil most likely leave it bare and just give it a coat of clear for protection.
Hope you like the way it turned out!
I do not think i will be doing one of these again any time soon!
It was a lot of work!!!
But it looks so much better that when i picked it up!!!
Let me know what you think!!
Go easy on me, this is the first time i have attempted something like this! ;D
Andrew
Tail stock restored
Andrew
