Here are some pics of my first project.
I chose a finger treadle engine because it is very simple, I get to turn a flywheel , axel and crank and I get a visible result of my training.
Unfortunately my shop is rather limitet (I'm working on that one ;-) ) and I spend all my consentration on getting it right, forgetting to take photos at every step. However, here are some pics of my first mandrel. I needed to make a mandrel to finish my flywheel and my first attempt in axel steel failed. I think I know why though. I still use the original toolpost and it leaves me with a too high placed tool. It rubbs. I bought a Quantum, QCTP, but the size was wrong from the dealer and I'm waiting for a replacement. I tried shimming the rear of the tool, but that is only partly successful as I get an weird cutting angle and a rough result in steel. The alu mandrel didn't last long, the threads broke and the flywheel came loose just as I finished a cut. I learned a lot from the excersize and even modified a drillbit to cut brass, following a tip on this site. Worked beautifully!
Onwards and upwards!
Orjan
Orjan
