cfellows said:Had about 15 minutes of heart palpitations and cold sweats a little while ago. I cleaned up the lathe and checked everything over, then went through the startup procedure, making sure to follow directions. First I set everything to off and plugged it in. Then I put the forward/reverse switch into Forward. Turned on the Off/On switch, light comes on, so far so good. Then I turned on the speed dial and wound it up a quarter turn... nothing. Checked things over and tried again, nothing. So I wrung my hands and ground my teeth and wiped the sweat from my brow for about 10 minutes. Finally went back to the instruction book. Funny how the actual operating instructions start on about page 10. The first 9 pages are warnings and disclaimers... Anyway, to make an already long story short, I discovered that the chip shield arm has an interlock switch. The lathe won't operate unless the chip shield is in the operating position (OK, that's got to go!) Anyway, fiddled with the chip shield arm until the little detent pin popped into place, tried the startup procedure again, and bingo, off it went.
It's all good...
