ke7hr
Active Member
- Sep 9, 2009
- 42
- 2
Even with novice machinist skills, I have been wanting to build a motor for some time. I have looked as a myriad of plans and projects, finally settling on a simplified Jingle Bell Motor based on the one at
http://npmccabe.tripod.com/jinglebellmotor.htm
I downloaded a FREE 2D CAD program, DoubleCAD XT, and set about redrawing the motor in a simplified way to suit my totally manual "3 in 1" machine and my (hopefully) budding skills. I posted the simple plans in the download section of HMEM with permission.
Today I got a chance to start cutting and making the motor. The frame seemed like the place to start. I cut the .500" thick aluminum a bit oversize to mill it to size.
<hr>
The step in the frame was then milled to size.
<hr>
The hole locations were then laid out. I drilled then reamed the bearing hole and finished the rest of the holes on the front.
<hr>
The holes for the air (steam) inlet and outlet were cross drilled. I modified the frame from the plans to include a 1/4-20 tapped hole for the inlet to allow a nylon bolt to serve as the air hose attach (with a hole drilled through the center of the nylon bolt).
<hr>
The base attaching holes were then drilled and tapped.
<hr>
And, finally for today, the frame is finished - waiting more parts to be built (after work tomorrow).
<hr>
<hr>
<hr>
<hr>
<hr>
