I've picked up a new (to me) Atlas 10F lathe today and although it's the same as my current one it has a T-slotted cross slide which I think will be much more useful. The only downside is that the crosslide sits about 7mm higher than the old one and I'm going to struggle to get some of my insert tooling to sit low enough to hit centre height.
Thinning out the tooling and toolholders will deal with most of the issue but the other problem is that the toolholder itself will have to sit right at the bottom of the toolpost. In this position the piston will only be working on the top half of the holder and I can't imagine this would be particularly good.
I therefore need to take about 5mm off the bottom of the toolpost (pic attached). As I'm still at the early stages of the learning curve I'm not sure what would be the best way to remove this material so should I be using an end mill, fly cutter or chucking it on the lathes and facing the end ?
Thanks
Jim
Thanks
Jim
