Hi All.
I have a chinese lathe from Seig. They make all the others in the various guises around the world. Apart from several design faults they are generally good machines. To keep the price down they fit standard bearings in the head not taper. This builds a little play and instability into the head and means the plastic gears smash easier as they are constantly moving in and out of alignment. The bearings on mine started squealing under the stress of turning. Grease did not make enough improvement so I decided to change the bearings for tapers. I only live about two miles from Arc Euro Trade so am a regular visitor there. For less than twenty quid I bought two bearings and a plastic gear wheel to cut up to make a new spacer. The bearings were Timkin rather than the usual Nacho so I have by far the better ones. On the Arc Euro web site he has a very detailed set of instructions including photos for the whole process. I printed them out and followed to the letter. Both sets of my gear wheels were smashed so I changed them as well. Over two days I spent about five hours doing this.
The change in the machine is fantastic. The movement is very smooth and does not jerk at low speeds. The lathe will now turn very smoothly at 20rpm and will now turn to the full 3000rpm and then a bit more. All the stress in the lathe has gone and it is now a pleasure to use it making turning easier and the finish a 100% better.
If you have one of these lathes and have not changed to taper bearings DO IT NOW....you will not regret it. For about twenty pounds you are effectively buying a new lathe. Spend a little more and replace the gears aswell to make sure but DO NOT change plastic for metal. They are plastic to protect the lathe and designed to smash under extreme load. Bearings and gears are only thirty pounds plus the postage. I walked in and collected. The guys there are very knowledgeable and easy to talk to. I have nothing to do with the company except being a very satisfied customer. Check out their website and see the range they do...it's not just machines.
www.arceurotrade.co.uk/
Julian.
Julian.
