Hi,
working on my first engine (a 7.7cc single cylinder 4-stroke).
One of the parts that always sounded to me like a tricky task was the piston rings. So I am making one early in the build. I am using the neat no-heat method outlined by b.lindsey here: http://www.homemodelenginemachinist.com/index.php?topic=6014.msg103346#msg103346. Cast iron is the material.
When it came to compressing the ring blank in the fixture and turning the OD to size (gap compressed in fixture) everything was great until I opened up the fixture and released the ring. The gap which had been 3.4mm has shrunk to about 1mm. This isn't something I have heard about, maybe there was some residual stress in the ring and when I machined the OD to size this was relieved? Seems a little unlikely, I only needed to take a cut of around 0.25mm from the OD anyway, then polished the surface with 1200 grit and oil to dead-on size and released the ring to find the gap problem.
I haven't yet machined the inside of the ring as I would really like to understand what has caused this, what (if any) real effect it will have on the engine and whether it is a problem someone else may have seen and overcome. Any ideas?
Thanks/
Thanks/
