What a great rally of advice
So an end mill can have 2 or 4 flutes- or grooves that are twisted around the shank.. that give effect how much material is being cut at once, and related to the type of material being milled and would seem to have a direct effect on speed and amount removed in one pass?
The end of the mill can cut ( able to PLUNGE) or be ball ended so it ran ride along on a plane and cut perpendicular to an established plane. Like a ball ended router bit..
An end mill range suggested by Kludge 1/16,1/8 up to 3/16 ( cutting end) But Mr. Kludge
is there a spec shank diameter? 3/8 for example, and if so all end mills should be that size..I am used to drill chuck steps - so 1/4, 3/8 1/2 etc - Just double shecking this small point
I notice that I may need an end mill holder to lock the end mills into ( I saw a steel custom version of one of these on one of the sites that Kludge shared above..$18 and some change for a steel... stated up to 3/8" or 1/4" - would one be the best all round choice?..the 1/4" since my lathe can only handle end mills of 3/16" or do I need the heft of the 3/8' more ..
Try to have some end cutting, at least one ball end end mill.
And a fly cutter- thanks Bog for that video--- that was spot on. Now since my little lathe is small..small - is there a fly cutter diameter that I should not exceed?
Now that you all have proved yourselves so helpful.. I shall try to read , some , study up some and then ask questions.. I am pretty handy, have a good mechanical sense 20 years ago I was a auto mechanic for Cadillac,,, but the only lathes I saw were for brake rotors...Not very enlightening..
I do have a couple of old lathe books " Machine Shop methods by Milne and an South Bend lathe book reprinted form the 1930's.. + this forum - I am not too scared
Gentlemen - Thanks.... and if it applies, have a great Labor Day Holiday
