- Oct 9, 2009
- 74
- 37
I know this subject has been hashed over a million times but I have a question that I haven't been able to find an answer to.
Will making a cast iron piston ring to the relaxed size od and the proper thickness (size that will fit the cylinder bore and piston when compressed with proper gap), then heat treating while the ring is still unbroken, and then grinding the gap in the ring make a good ring.
I am building a .750 bore twin (Dale Diertich's design) and thinking of turning the rings to an OD of .812, heat treating, then cutting a gap of about .200 in the ring. When compressed the ring should fit the bore with a .005 gap.
The advantages I see in doing this is that the ring starts out perfectly round and the chance of warping when heat treating is greatly reduced.
What do the old pro's think- anyone ever done it this way?
