I am considering - read dreaming - about making a hot air engine. Jerry Howell recommends titanium for the hot cap.
So, I look on eBay for some titanium and after coughing at the price, continue dreaming.
However, I contacted the vendor about machineability, asking about using HSS tools in a Myford lathe for cutting titanium and the very helpful reply I got back was:
" Hi Dave.
The main reason we use carbide tools is for the higher cutting speed snd tool life.
You can turn titanium fairly easy provide you * Use low cutting speeds. * Maintain high feed rates. * Use copious amounts of cutting fluid. * Use sharp tools and replace them at the first sign of wear. Tool failure occurs quickly after a small initial amount of wear. * Never stop feeding while tool and work are in moving contact. Allowing a tool to dwell in moving contact causes work hardening and promotes smearing, seizing and tool breakdown. In summary we use a small Myford lathe for small detail parts with no problems. If you need any further techincal help please feel free to contact us at any time. Best of luck "
Perhaps the above may be of interest to others contemplating the use of titanium.
The Emerald Isle
" Hi Dave.
The Emerald Isle
