B
Bogstandard
Guest
For all those who are building or planning to build this flame licker from the old plans, Jan has updated two parts of the plan that were causing a slight problem.
When drilling the main cylinder, you had to try and drill a 2mm hole, the full length, and a standard drill just would not reach. He has modified his plans to take account of this and also reduce the friction on the rod that passes thru it.
Attached here are the two mods.
