Inside-Out steam engine - Finished
Help Support HMEM:
cfellows
After a few trials and tribulations I'm considering this engine finished. The final piece was the birds eye maple base. Went down to my local Woodcraft store and found a little piece 24" long x 4" wide by 7/8" thick (small in size, big in price - $22.00).
Here's the glamour shot...
Here's the remainder of the pictures, the video is at the bottom...
And the video...
[ame=http://www.youtube.com/watch?v=r2Ku5yF4EsM&list=UUZB8pRNp9Plbd0-T9RmyR9g&index=1&feature=plcp]http://www.youtube.com/watch?v=r2Ku5yF4EsM&list=UUZB8pRNp9Plbd0-T9RmyR9g&index=1&feature=plcp[/ame]
Chuck
hdwrench1
Very nice work Chuck. I am envious of your work.
Wayne
doubletop
Nice one Chuck
Is the flywheel really running in the opposite direction of the crank or is that just camera strobe effect?
Pete
SBWHART
Very nice engine chuck and that base realy set it off.
:bow: :bow: :bow: :bow: :bow:
Stew
Blogwitch
Ex Bogstandard
HMEM Supporter
Crewe, Cheshire, UK
Chuck,
You never cease to amaze me with the innovative engine designs you come up with, and they all run perfectly.
Very nice indeed.
Ken I
Cape Town, South Africa
Chuck, that is just lovely and a nice looker too.
I'm guessing the tapping sounds are the piston/shaft assemblies deadlengthing and being spooled from inlet to exhaust in the chambers at the end.
Presuming my thinking is correct that design will simply stall at the ends at slow speed apart from the inertia and the other cylinder "pushing" - I'm guessing further that the exhaust timing was fiddly and needs to be more effective than the inlet.
'Fess up - how did you do it ?
Neat trick.
Ken
cfellows
Wayne
Thanks, Wayne, it did give me a few bad moments.
Foozer said:
Like the sound, sorta like a teletype. Hypnotic
Robert
Thanks, Robert, the clicking sound isn't nearly as loud in real life... more of a thumpety-thump.
doubletop said:
Nice one Chuck
Pete
Thanks, Pete, that's just the strobe effect, the cranks and flywheel are all solidly connected.
larry1 said:
Great Job, Chuck. larry
Thanks, Larry.
Stew
Thanks, Stew, I took a little more time on this base than I usually do. Also bought a special piece of wood... usually I just try to find whatever is laying around that is right size.
Bogstandard said:
Chuck,
Very nice indeed.
Thank you kindly, John. It definitely had me going in circles for a while, but once I sealed up all the air leaks, it came together nicely.
Neat trick.
Ken
Thanks, Ken. Yes, the tapping sounds are the cylinders running into the pistons and pushing the support rod about 1/4" to reverse the inlet and exhaust ends. I installed o-rings on each side of the piston to soften the sound. Flywheel and cylinder inertia carry the rotation through the dead spot at the end of each stroke. Actually, I never had any problem with exhaust timing. That part seemed to work fine right out of the chute.
Chuck
cfellows
Here's a drawing of how the engine works.
On the actual engine, I had to make the end support blocks thicker so I could attach a piece at the end of each support rod to stop it's motion. I drilled exhaust holes down from the top of the block.
Chuck
IronHorse
Nice job on a very interesting engine design.
IronHorse
b.lindsey
Chuck, that is just totally ingenious...and beautifully executed too. This one definitely deserved that "special" piece of birds eye maple and the sound is simply mesmerizing also!!!
Bill
crab
confused
I really like this one Chuck,I think it's one of your best yet. Thm:
Crab
doubletop
It with the inside out cylinders it would be a neat and complimentary effect if the flywheel did go in reverse of the crank. Some epicyclic arrangement maybe.
Its still a great job
Pete
Troutsqueezer
I can see why you picked Bird's Eye Maple for the base, Chuck.
Thinking outside the box, isn't that what they try to teach young people these days? It seems to come naturally for you. Nice, very nice.
ShopShoe
Senior Member
The more I look at this the better I like it. The video really shows it running well and it sounds great.
I think the look of the metals you used and the choice of wood really makes this a stand-out.
--ShopShoe
AussieJimG
That's a great sounding and good looking engine Chuck and a worthy addition to your collection of ingenious machines. It is sure to be a real conversation piece.
Congratulations and thanks for sharing.
Jim
cfellows
Thanks to everyone for the gracious comments. I usually gravitate toward darker woods like Walnut and some of the exotic woods like Wenge, Cocabola, etc. But I do have a soft spot for naturally finished birds eye maple. It has a very clean and uncluttered look to it.
Already thinking about my next engine. You can see from the picture below I may have a hard time finding a place to put it!
Chuck
Path
Senior Member
Nice job ... :)
Looks like you are going to have to make some furniture to house your next engine. :big:
Thanks for sharing. ;)
Pat H.
