Can anyone direct me someplace that I can learn proper techniques from? Such as what needs to be done first when building from plans.
Here is a resource , actually a collection of resources that may help You.
http://www.homemodelenginemachinist.com/index.php?topic=9413.0
The Basics are all over, in many books and some videos. There are video machining courses you can buy or rent you may be able to take classes at a local tech school or college. If you are luck there may be a fellow Home Shop machinist in your area willing to teach you.
As far as step by step directions for building a model I can think of a couple good options
1) Buy and read all the Shop wisdom of Rudy Kouhoupt books. His plans come with instructions. The plans are all in book format now.
2) )download the Elmer Versberg plans from John-Tom.com again insructions with the plans.
If you don't makes mistakes, you're not learning.
I have said before The home Engineering shop is like a college engineering lab. No mistakes but lots of learning experiences. Sometime you just need to make a practice part before you make one for an engine. heck sometimes you need to make three practice parts.
Keep a notebook and calculator on your bench. do not be afraid to calculate the next cut. And take notes and Photos as you go. If a setup works great use it next time if you blundered document that as well as a pitfall to avoid.
Got my stool to sit on and now to trouble shoot the mini mill since it keeps shutting off when I put a load on it, even drilling large holes.
It is likely the mill safety cutting in. Mine does the same thing . the mm is not a Bridgeport and brass and plastics will grab a drill bit and try to suck it in.
There are two ways to avoid this 1) step drill start small then make the hole progressively bigger using larger bits in small steps. the other method commonly used for plastics and brass is grind a zero rake angle at the cutting edge.
You may be able to adjust a pot on the control board so the safety does not cut in as soon but it is like just needs the operator to not take greedy cuts.
And do not be afraid to ask for help here if you need it . We all have times when we cant seem to find an answer we need in the "book"
I help run this board have worked as a pro machinist I still ask questions no one knows it all.
