rhankey
- Feb 21, 2011
- 176
- 30
Maryak said:Sorry John,
But if it's gearcutting then you do need dividing plates. The vernier on a rotary table is IIRC at best 10 secs of arc on the larger tables, on my Vertex 6" it is 20 secs.....so say 49 teeth
=360/49, = 7.346938776 deg = 70:20.081632653':48.97959184" rounding gives 70:20':49" or at best say 50 secs, then the error = 1.97959184*49 = 97 secs or 1.616 mins. On my Vertex the error is a minimum 8.979 secs or 7.34 mins!
I don't think you can afford the error the vernier will give for gearcutting.
Best Regards
Bob,
In using your example of cutting 49T, I can understand that the cumulative error of advancing the RT 7deg:20:49 to get to the next tooth position could result in material error by the time you complete a full revolution. Wouldnt it be way more accurate to compute a set of absolute deg:min:sec settings for each tooth (eg: n * 7deg:20:49) using Excel (or whatever method of your choice)? This way, individual teeth may be +/- a lets say 50 sec based on the accuracy of your RT, but will average out to being fine. This might not be close enough for car differentials where they need to achieve crazy accuracy, but for our small engine gear cutting needs, I cant imagine this being a big problem.
Certainly a set of dividing plates makes life a lot easier for gear cutting, but I cant see why a RT without plates cant be plenty accurate enough.
Am I missing something?
Robin
