idahoan
- Oct 7, 2008
- 594
- 210
Here is a set of unmolested castings for an Elmer Wall Duplex Mariner 2cyl 2 cycle IC engine.
There are a couple items missing; the timer lever casting (which would be an easy part to make), also the center bearing casting which was nothing more that a slug of some sort of high grade cast aluminum (also an easy part to to make).
There is no carburetor which I believe was purchased as a separate item from Cole's. There is no cylinder liner material; but now days cast iron bar stock is readily available.
So its pretty much what you see is what you get.
$225.00 which includes flat rate shipping to anywhere in the continental US.
Thanks,
Thanks,
