I've been working on the plans for this engine.
I'm concerned about lubrication to the lower end. All the fuel/oil mixture is in the head and cylinder and none in the crankcase. The old Webra T4 engine also deal with this problem. But, I've seen two different versions of the Webra.
One engine inducts fuel through the crankcase and one doesn't. I can only assume that the change was made because Webra determined that enough oil was blowing past the rings to adequately lube the crank.
