Grimm1966
- Jun 3, 2012
- 9
- 1
I started an Elmer's wobbler a couple of months ago, it's almost ready to test drive.
Here is the link to the plans (skip the #25, don't know why they were included together):
http://www.john-tom.com/ElmersEngines/25_26_WobblerBoiler.pdf
Here is what it looked like a month ago:
Here is the progress since then:
I did find one problem with the plans, either that or I read them wrong. The radius of the boiler top turned out much too large if you make it 2" radius. I found that 1" radius is almost perfect. Also I'm building this from just stuff I had laying around. The stack has a smaller diameter (.375") then the 1/2" called for in the plans. We will see how well it works out. :-\ There are other small differences that I had to do because I didn't have the correct materials. One was the connection from the boiler to the engine. My K&S copper tubing's wall was much too thin to put threads on it, so I just soldiered it to the engine. I can get the engine to tick over a couple of times just using my breath (I don't have an air compressor). So I'm going to take that as a good thing.
Now all that is left is to paint it and put the boiler lagging on then the live steam test. :big:
Jason
Jason
