- Mar 9, 2010
- 597
- 704
This is a double acting 3 cylinder engine I just completed. This one was not done from plans, but made up as I went to fit the size of the chunks of brass/steel that I had left over from previous engine and clock movement projects. Cylinders are 5/8" bore with a 1" stroke and a spool-valve with a 5/16 bore. The piston and valve rods extend through the top of the engine giving a bit more eye-candy than stopping them internally (watching the coumpound engine in the steamship Sabino at Mystic Seaport Museum gave me that inspiration).
Came out pretty well, self starts, runs fairly slow on about 5 or 10 psi (my guage does not read well at low pressures, not sure what actual pressure was), and spins up nicely at higher pressures. Made a fun winter project. Now I gotta figure out how to hook it up in the kayak for next spring....!
Here is a video of it running:
[ame]http://youtu.be/NReWxrjCVa0[/ame]
There is a build thread of it in the WIP section - here is a link:
http://www.homemodelenginemachinist.com/f31/double-acting-triple-using-up-spare-pieces-22086/
