Having fitted Digital Read Outs with remote display units to my Chester Conquest Mill the passage of time has thrown up an irritating problem. The four pin plugs that fit into the scales have proved to be very insecure. On more than one occasion the signal to the display has disappeared in the middle of a tricky machining operation leaving me at sea without a rudder, so to speak. Does anyone have a solution to this problem ? I am tempted to superglue them in position but suspect I may live to regret such drastic action though I cant think why !
My second question is posed in the hope that there may be an electronics expert in our midst. I have also found that batteries in the remote displays can expire without notice and again this always happens at a most inopportune time. One suggestion is to ditch the batteries and use a small variable transformer. On investigation there are two power leads in each unit one drawing 3 volts and the other 1.5 volts (the second 1.5 volt supply takes current back to the scale sensor). I have got as far as wiring the two units in series from a 6volt supply giving the required 3 volts to each unit but am at a loss as to providing the 1.5 volt supply in each unit. Any ideas anyone ?
John S
John S
