Hi,
I want to design an engine and i have some questions about bore volume compression ratio etc. I want to built a petrol engine and i also know and able to work some formulas regarding thermodynamics pressures temperatures etc. If you want to design an engine from where do you start, i was thinking from the torque or work right. Also can the rpm be increased in these small engines.
when you have determine the work you find the bore volume and the stroke needed to be able to compress that volume and achieve the right temperature to ignite the petrol.
I am not sure of this so any replies are appreciated
Drei
Drei
