hammers-n-nails
- Mar 22, 2009
- 206
- 0
ive been doing some reading on thread geometry this evening and realized that i have never considered a potentally important detail.
ill use a 1/4-20 UNC external thread as an example
is the 60° face of the thread supposed to be measured in a plane that is in line with the axis of the bolt, or perpendicular to the helix of the thread? in this case 11.31° if i calculate correctly
so as a practical example when single pointing a thread on the lathe should the cutting face of the tool which the 60° cutting edges are measured from be held level or at a 11.31° angle (downwards side left for right-hand thread)
i have always ground my tools so the cutting face is co-planer to the axis of the shaft with a 0° rake and have never had any obvious problems.
im pretty sure im doing it right but i thought it would be worth asking you more knowledgeable machinists about.
thanks in advance
Zach
thanks in advance
Zach
