student123
- Oct 31, 2009
- 183
- 0
Sorry if this sounds laboured , but here I go climbing the compressor learning curve
I just bought a compressor, to test my "easy build" wobbler
Not knowing anything much about what to buy , I copied from John's website:
http://start-model-engineering.co.uk/machines-and-tooling/air-compressor/
and as recommeded go to 'everything airbrush' & got a model AS-09 airbrush compressor along with a hose (female connector both ends).
As an aside, I was considering a 'on demand' airbrush compressor - the guy at the shop said not suitable , get a diaphram type
I read the (fairly brief) instructions
When I get it out of the box theres two possible output sections , one capped with a white plastic cap[on left in photo - call it output A], one with what looks like a female connctor & a nut [output B]
"OK ..maybe I take the nut off B to reveal a male connector" - nope , instead inside theres a spring , so I quickly tighten the nut back up
then I look back on Johns website & see:
'http://start-model-engineering.co.uk/wp-content/uploads/2009/10/p1000443.jpg
Ok so now I know where the hose goes - on A
here are two info plates on the compressor
and
I then check the internet for a detailed guide but cant find one.
Some questions:
1. In the picture from John's website whats the glass/plastic cylinder thing on the left connected to the compressor ?
2. whatever it is , is it essential ? (Guy at the shop didnt mention any essential extras needed)
3. on the compressor it says "exclusively for use with a bleeder type pneumatic tool". Umm whats one of them ? (able to loose off excess air ??)
4. Are there any "non bleeder" type pneumatic tools or applications (that I'm likely to encounter) I cant use my new compressor with? - ie are there restrictions I need to be aware of?
5. On one plate "after each use release pressure in airlines and receiver tank" - where is the receiver tank & how do I release it's pressure ?
6. On plate : "drain moisture trap after each use" - I cant see anything that looks like a moisture trap , where is it ?
7. In the instructions "Do not touch the hot parts do not touch the discharge line..." - which is the discharge line. (Output B ? - if yes am I supposed to connect a 2nd hose line to that for discharging purposes?)
8. How do I regulate the psi output ? (my guess is loosen connector on B to reduce air output from A )
(Bit tempted just switch it on & see what happens).
Anyway, thanks in advance,
Mike
and
Some questions:
Mike
