Howdy, Installed a new 4" 3 jaw on my 7x16. no name chinese, from micromark. It seems to be a decent chuck, but there is a speed range in which it imparts a shudder to the lathe.
below and above it runs reasonably smooth. speed range where this happens is going to be used a bit I would think.
I am not experienced on measuring chuck paramaters, but so far I measure .003 runout measured against the side of the chuck body.
I will try one more position on the spindle, this is the second try.
And the faces of the jaws with them about halfway open, was very impressed at no measurable run out on a .0005 indicator. and the small bits of work held in it look good upon completion.
so should I be concerned ? its still new enough to send back , I think.
the original 3" chuck did not do this.
