Casto Saw
mhh
Time to take a look at the old saw again!
It was running on motoroil and I wanted to run on coolant instead so it got cleaned up.
The shiny cylinder was made a few years ago, the old one was attacked by rust and was useless to say the least after the new one was made everything worked much better.
The arm.
Also a new switchbox was needed, the old one missed the lid.
Cutting again! works much better, before it had a tendency to chip a few teeth fairly quick because of the oil pressure being higher than it should be
Using oil caused a big mess, and it was pure hell to weld! ;D
I wish I had one of these! How long do you find the blades last?
Quite long and they should last a lot longer now because with coolant in the cylinder it makes a much softer stroke, also having different blades with various teeth numbers helps! It is a nice saw, but bandsaws are faster and cheaper in the long run(if you get one with a blade brush)
