I have this problem boring in the lathe in mild steel. The swarf builds up ahead of the tool and pushes out at the end of the bore like a small concertinad cylinder. I don't think it's the tool angles as the swarf curls out behind the tool (as I think it should) in the first 1 or 2 mm, only as the boring gets deeper. Especially bad using a slender boring bar in a deepish bore the boring bar gets deflected, pushing all that connected swarf ahead of if and a tapered bore is the result. PLease give some advice.
Thanks,
Ant
Thanks,
Ant
